Mobil 1Ext 10/30; 11K; Lexus ES350 07
Lakeside, Ca
Don't see too many 10/30 samplings. Actually, don't recall seeing any. Mileage was actually just over 11,700 miles with no makeup oil. Used ALS via Amazon's Wix Filter oil analysis kit.
Code:
DATE SAMPLED 15-Nov-15
DATE RECEIVED 01-Dec-15
DATE REPORTED 03-Dec-15
TIME ON UNIT 171000
TIME ON OIL 11000
OIL BRAND Mobil
OIL TYPE Mobil 1
OIL GRADE 10/30
OIL ADDED 0
FILTER K&N
OIL CHANGED 0
Metals (ppm)
Iron (Fe) 6
Chromium (Cr)
Lead (Pb)
Copper (Cu) 1
Tin (Sn)
Aluminium (Al) 2
Nickel (Ni)
Silver (Ag)
Titanium (Ti)
Vanadium (V)
Contaminants (ppm)
Silicon (Si) 16
Sodium (Na) 34
Potassium (K) 1
Additives (ppm)
Magnesium (Mg) 707
Calcium (Ca) 1147
Barium (Ba)
Phosphorus (P) 762
Zinc (Zn) 844
Molybdenum (Mo) 80
Boron (B) 37
Contaminants
Water (%)
Coolant No
Physical Tests
Viscosity (cSt 100C) 11.1
Physical / Chemical
Base Number (mgKOH/g) 2.8
DIAGNOSIS
Engine wear levels appear satisfactory for first sample. Silicon level (dirt/sealant material) satisfactory. Water content acceptable. Viscosity within specified operating range.
Action: Resample at next recommended interval to monitor and establish wear trend.
For 11,700 miles w no make up, those are some amazing #'s. The ES350 is really easy on oil - I service a 2007 as well and just change every 5k (takes 2-3 years) with dino. Good post.
Did better than the pp in the 2.5 with half the miles. I might just go back to M1.
Thanks for posting.
That's Mobil 1 Extended, to be clear. Might jump to Valvoline Max Life at the next change to see the difference. I didn't check the oil level before the oil change; looking at the contents of my oil container, the Lexus may have been short half a quart. Will monitor it better next time.
