Mobil 1 x-ref for Wix
North Alabama
Can any of you tell me what the corresponding Mobil 1 oil filter is for the following 3 Wix filters:
57035
51056
51348
Thanks in advance.
This was all that I could find.
"Should you have additional questions about our oil filters, please phone our Oil Filter Hotline at 1-800-882-0890 for assistance. Hours are Monday to Friday,
7 am to 7 pm (Central Standard Time), and on Saturdays from 7 am to 5 pm (CST)."
For being such a pricey filter, this is really lame. You should call them and see if they can actually figure it out.
M1102 - 51348
The rest aren't direct x'ref's
This is a PH3614 sized filter - a stubby 3/4-16 thread.
UPC Number: 765809570351
Principal Application: Various Lawn + Garden Equip w/ Briggs & Stratton Engines
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.305
Outer Diameter Top: 2.923
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=20/41
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 28
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.734 2.430 0.226
This too is a stubby 3/4-16 filter
Part Number: 51056
UPC Number: 765809510562
Principal Application: Various Lawn + Garden Equip. + Small Tractors w/ Kolher, Lister, Hatz, Kawasaki Engines
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 2.707
Outer Diameter Top: 2.921
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Burst Pressure-PSI: 325
Nominal Micron Rating: 19
Gasket Diameters
and, for that matter, so is the 51348
Part Number: 51348
UPC Number: 765809513488
Principal Application: Various Chrysler/Jeep (82-07), Various GM, Saturn (85-07), Lexus (90-07), Saab (67-07), Suzuki (86-02), Toyota (88-07), Yugo (86-89), Harley-Davidson, Various Lawn&Garden, Farm Equip.
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.404
Thread Size: 3/4-16
Beta Ratio: 2/20=21/37
Gasket Diameters
Hmmm ...wayne ..whaterudoin?
"Hmmm ...wayne ..whaterudoin?"
Gary,
I ask because the 3 Wix filters I posted will fit my new John Deere mower. I figured since the oil is only supposed to be changed every 50 hours, I might use a Mobil 1 filter, which I personally consider to be a better filter than a Wix. Th edifference in price is not an issue, since this would be a once per year expense. My JD mower would probably never need an oil filter as good as a Mobil 1 filter, but that's why I asked.
Mobil1 has a limited range of PN's.
If you have room, slightly longer, possibly some extra diameter, you should be able to find a good substitute for all those filters.
I would use the M1-102 in place of ALL three if there is room.
Since price doesn't vary much among sizes, if there is room the M1209 would be any extra long version.
All three WIX filters cross to the Mobil 1 M1-102. The filters you have are probaby all vary in height a little, but they all have the internal parts, gasket seal, and thread size so you can use the M1-102 to replace them all.
