Mobil 1 Triple Action Oil Color
CA
Not saying oil color is indicative of condition, but thought this was interesting:
On several vehicles where I have installed Mobil 1 Extended Performance Triple Action 5W30, the oil has become very dark within 1000 miles. Prior fills of M1 have not exhibited this.
On several vehicles where I have installed Mobil 1 Extended Performance Triple Action 5W30, the oil has become very dark within 1000 miles. Prior fills of Mobil 1 have not exhibited this.
I noted that the Mobil 1 Extended Performance 5w30 series TA starts out a darker amber color than say PP which is lighter in color . On a port fuel injection engine in good condition the Mobil 1 Extended Performance oil doesn’t change color much from the original darker amber color over its OCI . Whether an oil starts out light or dark should not have any impact on its quality . Lastly , some oils may darken early in an engine new oil fill if you switched oil brands from the last oil change . Mobil 1 Extended Performance 5w30 is a very good oil - use with confidence .
I run Mobil 1 High Mileage 5w30 Triple Action and mine stay pretty clean (my engines are clean)
But the last oil change was 6 months ago as I do 6 months or 5,000 miles, probably will do an oil change next month, if I notice a change I will share.
I noticed the exact same thing using Mobil 1 Extended Performance in my 2022 Pathfinder with 3.5L V6 DI, Im wondering if the Direct Injection has something to do with it.
What year is the Nissan in the pic?
It’s a 2010 Altima V6 with 59K, I have changed the oil every 2-3K using Full Synthetic 5W30 since new.
That's a normal Mobil 1 Extended Performance T/A oil color for almost 1000 miles, having a clean engine.
The same oil dipsticks I've drawn at the same mileage are similar and my family demonstrates 3k OCI rituals.
Carry on & sleep well.
I have heard that there are some additives that turn dark from uv exposure, i.e. combustion.
@RDY4WAR has mentioned this before. Would be interesting to take some virgin oil samples and let them sit under a black (UV) light overnight or so.
Previously I’ve noticed a reddish tint with Mobil 1 Extended Performance using their 0W20. Now I use their EP 5W30 and yes, for some reason my oil did get much darker, much quicker. The only other oil in my engine that has done that is Amsoil. Someone mentioned that it nothing more than just heat cycles, perhaps they are right. But it doesn’t happen when I use Pennzoil products (platinum or Ultra). No idea.
There was thread or a post about this a while ago. Ppl mentioned it was the color of the varnish being dissolved by the oil
