Again, unless the pump is on the relief, the "flow" is the same. Bearings are self-pumping, oil is supplied to them under pressure and they draw what they need from the pressurized galleries.
@Shannow (ME, expert in bearing design) has written on this extensively in the past if you search his posts.
Yes, oils are slotted into SAE grades using a standard test that measures flow under gravity at 100C. This is not meant to imply, nor are you meant to infer, that this is correlated with how an oil moves through the engine under pressure; it tells us nothing about the application. Just like this doesn't tell you how the oil performs at -30C, which is why we have the separate Winter grading system, or specifically how well it performs under high shear conditions, which is why HTHS is a parameter that many OE's mandate a minimum spec for. It also doesn't tell us how volatile an oil is, hence Noack. These are properties of a product under specific test conditions, which have varying degrees of relevance and which may be overridden by specific OE approvals.
300gr is a property (mass) of a projectile. But I cannot infer how that projectile behaves in service; I know nothing about the application, without information such as what calibre it is, what cartridge it is being fitted to, what rifling there is, if there is rifling...etc. An ILSAC 5W-30 can perform quite differently from an A3/B4 LL-01 A40 5W-30, even though both are 5W-30's with the same grade on the bottle; they are both 30 grades.
