I went out to Advance Auto to pick up some oil change supplies which included a new Mobil 1 oil filter. The correct part for my Subaru Forester is the M1-108 which is now designated as "extended performance." I always open the boxes in the store to make sure I'm buying the correct, unused part. I noticed something strange after opening two boxes. It appears that there has been a design change for this filter that you should be able to see in the pictures I attached. One has the spring on the bottom like I have seen in the past, and the other one has a blue cap at the bottom. I bought both to take pictures and will probably return one or both as I'm not sure what is going on with these filters. Anyone here use the mobil 1 filters and can chime in on which one is the one they use? Can anyone advise me on what is the function of the blue cap? Which filter would you use? [image]http://www.subaruforester.org/vbulletin/attachment.php?attachmentid=6928&d=1183781541[/image] [image]http://www.subaruforester.org/vbulletin/attachment.php?attachmentid=6929&d=1183781541[/image] [image]http://www.subaruforester.org/vbulletin/attachment.php?attachmentid=6930&d=1183781541[/image]
