After many hours of reading older posts on BITOG I have seen steady and sometimes conflicting debate about M1 base oils. Many suggest that M1 is now a group 3 base oil while other suggest M1 actually contains more PAO then the Mobil 1 Extended Performance line. I emailed Mobil and all they will say is that both are 100% Fully Synthetic. I'd like to hear some of you chime in on a 2 part question.
1. Which line do you feel has more PAO base stock, M1 or Mobil 1 Extended Performance?
2. Which viscosity grade do you feel has more PAO in basestock?
Some have suggested that the 0w30 or 0w-40 would have a higher quality base stock because of the larger viscosity spread compared to a 5w30 or 10w30. Thanks for your input.
