Originally Posted By: ADFD1
Originally Posted By: StevieC
Not engines with alloy blocks and those special bores
LOL!
I know you were kidding, but to touch on that point for a minute... My engine in my Santa Fe is all Aluminum with Iron-Liners for cylinder walls, and as far as I can tell and from reading my technical manual I only have hardened steel and/or aluminum parts in my engine leaving iron only for the oil pump and cylinder walls.
I have used M1 for the first 80K KM of my vehicle changed at 5-6K KM (3-3.5K Miles) as per the warranty.
Vehicle ran great but did show high Iron numbers in the 60's on the UOA's right through from the start to the 80K mark.
Since then I have changed to Amsoil and the Iron numbers have fallen to around 5-6 on average but I doubled the miles run on the Amsoil versus the M1. (Big Difference)
So if I have less iron in my engine than most engines running M1 and if M1 was only leeching the iron and not causing wear why were my numbers so much higher than most versus Amsoil at double the mileage?
Also with Amsoil my numbers indicating "ring" wear at 0's whereas with M1 they were slightly elevated in the 2-3's but nothing to worry about overall.
Not calling M1 out or bashing them, not stating that Amsoil does a better job at protecting my engine, just questioning the numbers is all... For discussion purposes.
Interesting about the iron numbers and the reduction when changing over to Amsoil. We have a lot of theories about iron and Mobil 1, my problem is they are just theories. If I ran a UOA and discovered Iron was cut almost 10 fold, I would forget about theories and deal with reality. Reality being Amsoil is giving "you" better iron numbers. Theories are fine, when they're backed up by hard cold facts they become reality. Until then I'd go by the numbers the UOA provides. Especially when a tear down is not practical for a back yard mechanic. JMO
AD
I didn't base my choice of switching from M1 to Amsoil soley based on this... There was other factors as well but it was surprising to see the drop in Iron whatever it was caused by in a pretty much, all aluminum engine!
Now I can't prove the heightened Iron numbers is wear and not leaching and I have never suggested as such, but being that only time will tell i'm not really willing to take a chance and wait to find out.
That being said I have 3 jugs of TDT and 1 jug of 5w20 that I'm going to run and do comparative UOA's for fun, but I will most likely go back to my trusty Amsoil.
The other thing about M1 versus Amsoil is, M1 is starting to get quite pricey up in this market and you have to watch for the deals to make it a good deal. I pay a few bucks more and I get Amsoil and sleep easy at night not worrying weather the Iron numbers are leaching or wear.
Dunno... Time will tell!
