Mobil 1 FS Differential fluid
Hello Everyone,
I cannot seem to find the answer to this anywhere and was hoping someone would know the answer:
I have a 1999 mazda miata, I am fairly certain it has an open diff (non-LSD), I have only been able to find Mobil 1 LS 75W90, I am assuming the LS stands for limited slip. Is it a bad idea to put this in my differential or will it be ok? If its a bad idea, any recommendations on a good brand to go with? I have had some bad luck with Redline in the past. Thanks!!
Originally Posted by bobbyjoe
Hello Everyone,
Did you check Castrol Syntrax?
Get Delvac 1 for $32 a gallon at Summit Racing … think it's there for the Porsche crowd as much as 4 wheelers
I use it in Eaton G80 lockers
It's good stuff and reasonably priced!
To answer the OP, though:
An LS oil will not harm or otherwise negatively affect a non-LS diff.
10-4, RVW … up until 4 years ago I ran the M1 LS many years in the Eaton's
(sand, mud, dirt, and a heavy foot on the blacktop when needed) …
I trust the D1 enough to put in the Tahoe a few days back … and some just arrived for the Z71 …
(M1 or Chevron goes in the front) …
It'll be fine for your diff. This is from Mobil 1's website:
•Meet or exceed the highest level of performance requirements of many modern passenger vehicles - including limited slip applications
Originally Posted by Char Baby
I have and will continue to use Mobil 1 75w90 LS in non LS diffs.
And Transfer cases. It's one if not my most favorite.
Hello Everyone,
Call 1-800-Ask- Mobil
