- Joined
- Oct 25, 2021
- Messages
- 2,799
Okay.EP has very much the same cleaning abilities as per their marketing. Also, 9.75 cSt @ 100C is on the lower side of SAE 30, so this is a turn off also
would assume they have obligations to blenders and looked at forecast - cut at home - know the feeling - I’m a DadIt’s amazing that they changed formulation so quickly after new product launch. That PAO must be really expensive. Now that PAO is gone, viscosity @ 100C is lowered — I am no longer impressed by Mobil 1 Advanced Clean, it’s just another Mobil 1 oil….
Why not? Its marketing, whatever makes you moneyWhy would you have 2 oils that are the exact same?
Okay.Why not? Its marketing, whatever makes you money
I dont know if they are the same, but marketing looks similar.People here know when two lubes are the same just as accurately as what year they will die - carry on …
AC:I dont know if they are the same, but marketing looks similar.
I’m wondering what else we’ve unknowingly bought.There will probably be a lot of SDS updates over the next year or so due to the supply disruption.
They are not the same at all. You can tell just by smelling them (important note, you can't discern anything meaningful about the formulas from smell alone other than they are different)I dont know if they are the same, but marketing looks similar.
Did you smell it before formulation change or after, maybe smell will change…?They are not the same at all. You can tell just by smelling them (important note, you can't discern anything meaningful about the formulas from smell alone other than they are different)
Advanced clean smells really mild and EP is a punch in the face strongest oil ive ever smelled, puts redline to shame (i am insane)
Im assuming before. It was probably a month ago i used some. Ill buy the newest bottling date i can find and see if it smells different. I still got the other bottle so i can compareDid you smell it before formulation change or after, maybe smell will change…?
Yes I just tried that last week their site said $4 Walmart cash. But when I checked out it only showed $3 Walmart cash so I cancelled the order.Its $26 at Walmart, plus you get $4 Walmart cash
Like these are normal times Mr Einstein …Here we go again Mobil 1 suck you in an then water down the product smh
Understandable, I do think they should differentiate the Advanced clean better but we just don't know how or to what extent its cleaning capacity is.Why would you have 2 oils that are the exact same? You wouldn't. We don't know much of anything yet since it's still fairly new but if you believe the marketing....that's how companies work.
