Hello BITOG Community
Long time lurking finally joined . Changing all the fluids in both of my 2018 Silverado 1500's.
Ive got a question about Mobil1 75w90 synthetic gear lube for
changing my diffs. The front specs 75w90, the rear wants 75w85.
Any difference that matters here?
One is bone stock . One is lifted 10.5" running 38" tires.
On the lifted one I'm swapping the rear differential cover for an aftermarket PML cover with drain plug and fill plug and 20 oz. more capacity.
I have a case of this Mobil1 on hand so I want to use it. Its about a year old if that matters.
Is Mobil 1 gear lube any good?
Sure I could run over to the amsoil guy down the road and get some extreme duty but I already have this.
Thanks for your reply
