Here is an analysis that I just got back from Terry at Dyson Analysis. The oil was Mobil 1 5W30 SS with 3634 miles on oil and 76,395 total miles on my 1996 Acura Integra LS:
Results ppm/% Comments (blank=normal)
Wear
Copper 2 low
Iron 6 low
Chromium 1 low
Lead 3 low for a honda,excellent
Aluminum 2 low
Silicon 13 average to low
Tin 0 low
Additives
Molybdenum 37
Sodium 5
Magnesium 357
Zinc 635
Potassium 1
Phosphorus 588
Calcium 1560
Physical Properties
Water negative
Fuel negative
Antifreeze negative
Soot 0 clean, no solids forming
Oxidation 26 scale 0-199 very low,13%
Nitration 48 scale 0-199 average 24%
Sulfur 0 no fuel sulfur
TBN 10 excellent retention
Vis@100 C 9.9 30w perfect
Final Comments : "This looks like tri syn and not super syn or transition between two formulation. Whatever it is the wear values are excellent ! Very clean running engine. This oil engine combo can go 6000 to 7000 safely between changes."
The oil was the first batch of Super Syn to hit the shelves. The engine is the 1.8 142 HP Non-VTEC engine. A Honda OEM(Filtech) oil filter and Honda OEM air filter were used. The car is driven 200-300 Miles a week with 75% of the miles hwy and %25 city. I drained the oil completely for this sample and am currently running Mobil 1 5W30 SS with a K&N oil filter. I plan on running this new batch 6000 miles before I sample. I am very pleased with these results. What do you guys think?? -Joe
Wear
Copper 2 low
Iron 6 low
Chromium 1 low
Aluminum 2 low
Tin 0 low
Additives
Molybdenum 37
Sodium 5
Magnesium 357
Zinc 635
Potassium 1
Phosphorus 588
Calcium 1560
Physical Properties
Water negative
Fuel negative
Antifreeze negative
