quote:
Originally posted by TooSlick:
Chip,
The presence of Fe/Cr/Ni is the signature for stainless steel. This typically comes from abrasive wear of the intake/exhaust valves. I know how bad the sand can be in Barstow - I was stationed at Edwards AFB for 4.5 years in the mid 80's.
It looks like you are ingesting some fairly large sand particles and this is increasing the bearing wear. I'd recommend checking the entire intake system for leaks and inspecting the airbox downstream from the air filter for dirt.
Your winter analysis results and summer analysis results are pretty close, so I don't think the oil is too thin. However, if you drive through sandstorms on occasion, I'd try a 4000-5000 mile change interval or consider installing a by-pass filter. By-pass oil filters do an excellent job of preventing abrasive wear even in off road agricultural applications.
Tooslick
