Mobil 1 5W-30 -vs- 0W40
quote:
Originally posted by Greg Netzner:
The revised M1 specs dated 10/02 are listed as:
cSt @ 40C: 5w30=53.7, 0W-30=54.8
cSt @ 100C: 5w30=9.7, 0W-30=10.1
Visc Index: 5w30=169, 0W-30=176
Pump Limit: 5w30=-51F, 0W-30=-58F
So, yes, there is a slight all-around benefit to the 0W-30. I'm still just guessing that the 0w30 won't leak any more than the 5w30 since it's already thicker at 40C/104F than the 5w30, but that it probably will blow-by more at cold start (when it IS thinner) in a worn engine....
I had to read this 3 times.
Hard to get into my mind that a 0w30 oil is going to be thicker than the 5w30. Where can I find the same data for the 10w30 or if someone has it please post it. I may have to consider going from my 10w30 to the 0w30 on next oil change.
I know it's hard for a lot of people to think of how a 0w30 oil can be thicker than a 5w30 at operating temp, but when you look at what it takes to qualify as a 30wt, maybe it'll make more sense. In order to be an Xw30 oil, it has to be between 9.3 and 12.49 CST at 100c. A 0w30 oil like Amsoil is pretty thick, it's around 11.9 CST at 100c. But Mobil 1's 10w30 and 5w30s are both at around 9.7 to 9.8 cst at 100c. So you can see how it's possible for there to be vast differences in the oil's viscosity at operating temp, while still actually being within the 30wt range.
I've read quite a few posts here about a lighter winter weight oil (ie 5w30) consuming more than a heavier winter weight (ie 10w30) and I just can't understand it. I do understand it if the 5w30 shears down to a 20wt and the 10w30 doesn't.
(other numbers snipped for space reasons)
I don't think you are going to get any blow-by when the oil has a visc of 50 something. I think the only important visc when dealing with consumption is the visc @ 100C.
Cressida,
For all practical purposes, the Mobil 1, 0w-30/5w30/10w-30 are the same viscosity @ 210F. However, the 0w30 and 5w30 do use lighter basestocks, so they will more readily evaporate at high temps. So even though they are the same viscosity at operating temp, you may see significantly less oil consumption with the 10w30 than you would with the 0w-30.
The other reason why the 0w30 evaporates more easily is that some of the VI modifier actually cooks off at high temps. A very wide range synthetic like a 0w-30/0w-40/5w-50 will always have a relatively high evaporation rate, in comparison to a 10w30/15w-40/20w-50 synthetic.
quote:
Originally posted by Chris A:
[QB]I've read quite a few posts here about a lighter winter weight oil (ie 5w30) consuming more than a heavier winter weight (ie 10w30) and I just can't understand it. I do understand it if the 5w30 shears down to a 20wt and the 10w30 doesn't.
As a general rule, the 5w and 0w oils are more volatile than the 10w. This isn't always the case, but it is the case with Mobil 1's 30-weights. I'm running Mobil 1 0w30 now and it didn't shear at all in 7250 miles, however my oil consumption is high with it. My consumption was 3X higher with the Mobil 1 0w30 than it was with the 5w20 conventional oil, and it would have been even higher had I done any amount of freeway driving. I wouldn't recommend the Mobil 1 0w30 for Honda's K20A3 or K20A2 engines for this reason.
Cressida,
cSt @ 40C: 10w30=61.3, 5w30=53.7, 0W-30=54.8
cSt @ 100C: 10w30=9.8, 5w30=9.7, 0W-30=10.1
Visc Index: 10w30=145, 5w30=169, 0W-30=176
Pump Limit: 10w30=-42F, 5w30=-51F, 0W-30=-58F
From what I've read on this BB, ALL the Mobil 1 stuff tends to run on the low end of whatever range they're in. The greater difference between the 30wt Mobil 1s is in the warm-up; the 10w30's thicker at 40C, & then all the 30s are real close at 100C; I don't know how much difference 0.3, 1, or even 10 cSt makes.
In Eric's case, he's got a brand new engine & a warranty to consider besides his moderate climate. Because he drains so frequently, he probably doesn't need to spend the extra $ on a Grp4 syn, but I understand his desire to use one anyway.
My goals are to decrease my maintenance & volume of waste oil while increasing fuel economy & engine protection. For my non-turbo 1990 Saab, I'd rather run the Mobil 1 0w30 for gas savings & better cold-flow (especially since it's been ACEA upgraded for extended drains, along with the other Mobil 1 30wts), but didn't know enough about it when I decided to put in the Mobil 1 15W-50; yes, I'm concerned about increased oil consumption because of the age of the engine. In my 1999 turbo, I've decided to switch to the Mobil 1 0W-40 for better engine protection at the expense of fuel economy. Right now it loses no oil in 10k mi with a Grp3 10w30, so we'll see what happens with a 0W.
I'm still trying to sort it all out while not giving myself a mental hernia.
This board's been a fantastic resource for me. I just can't tell if I'm getting less dangerous, or more...
In the Supersyn family
0/40 21,700 cold pumping cp @ 40C
0/30 22,600 " "
5/30 23,900 " "
10/30 10,250 " "
15/50 14,050 " "
Does that mean the 10/30 and the 15/50 has less adds to burn off and more syntetic base oil in a quart? Are these two the most stable of the rest?
Is the 10/30 also the superior cold weather oil?
Those numbers are:
Cold Cranking first and cold pumping second, CP @ °Celsius
0/40 4,301@-35° 21,700@-40°
0/30 3,800@-35° 16,250@-40°
5/30 3,600@-30° 12,700@-35°
10/30 3,848@-25° 10,250@-30°
15/50 5,234@-20° 14,050@-25°
Eric,
Pump Limit: 5w30=51F, 0W-30=58F
(These numbers are the same as the specs dated 8/02; they corrected some other misprints.)
So, yes, there is a slight all-around benefit to the 0W-30. I'm still just guessing that the 0w30 won't leak any more than the 5w30 since it's already thicker at 40C/104F than the 5w30, but that it probably will blow-by more at cold start (when it IS thinner) in a worn engine. I'm also guessing that evaporation may be slightly higher, but not to the point where it would catch up to what the 5w30 would be doing in the same period of time.
quote:
No. You can't directly compare the cold pumping and cold cranking specs across the cold temp designations like that. You can directly compare a 0w's cold cranking and cold pumping specs with another 0w but not a 5w. For a synthetic oil, it's viscosity will increase by about 1.7 every -5*C change in temp. So if you want to guesstimate what M1's CP spec would be at -35*C, it would be 10,250cP X 1.7 = 17,425cP.
Where does that come from? In the above specs, a -5C drop results in 3-5 times the thickness.
Greg, M-1's 0-30, 5-30 and 10-30 are ONLY ACEA A1/B1 for fuel economy, not the more stringent A3/B3. Only the 0-40 and 15-50 are rated as such.
Dr T,
Actually the M1, supersyn is ACEA A5/B5 rated in the 0w-30/5w30/10w-30 grades. If you go to the Lubrizol website you'll see that the A5/B5 oils have to pass the same tests as the ACEA A3/B3 oils. They are basically low viscosity versions of the older, thicker formulations.
Most newer VW/Audi engines in Europe call for the VW 503/506 spec oils, which are primarily 0w30 grades. These roughly correspond to A5/B5 oils ....
quote:
I think I got it from TooSlick who has posted this many times. I've checked the figure on a temp/vis chart and the conversion is reasonably accurate at low temps.
quote:
Originally posted by Ross:
Please inform me...
I have always used Mobil 1 5w30 in my cars until they reach about 90,000 miles, then I swith to Mobil 1 10w30. I have read the forum about how good Mobil 1 0W40 is, but I thought that X-W40 weight oils weren't recomended in todays tight tolerance engines. They are just to thick at higher temps.
I also thought that that oils that have a big differnce bewtween the first and last #'s (the 5 and 40 in 5W40) were not as good as oils having a smaller difference. Also wouldn't a 0W oil be more likely to leak from a seal than a 5W oil.
So in conclusion, is Mobil 1 0W40 better over all in my 2000 caravan 3.3L than Mobil 1 5W30. I change oil about every 4-5K, and currently do not notice any measurable oil consumpition between oil changes.
Thanks for your advice....
And gosh darn it, I just bought 2 cases of Mobil 1 5W30 tri-syn at walmart..
Ross,
It seems that the main reason that 40 wt. oils are not recommended is to give the auto makers a sliver better fuel mileage to avoid CAFE penalty payments.
The big spread in vis numbers, 10W-40, etc., relates to conventional oils...they need to add too much viscosity index improver (VII) additive. Synthetic oils listed as 0W-40, 5W-40, 15W-50, etc., have an inherently higher viscosity index due to the superior base stocks, and need less VII.
A 0W oil is only thinner than a 5W or 10W oil at low temperatures. A 0w30 and 10w30 are essentially the same viscosity at operating temps.
Mobil1 0W-40 is a different formulation than the xW-30s. Mainly, it has superior High Temp/High Shear viscosity specs. Yes, it's a slightly better oil.
Your Mobil 1 TS 5w30 is still an excellent oil. Use it up and feel good about it. We've also heard that the new Mobil 1 0W-30, 5w30, and 10w30 are essentially the same oil with different labels for marketing purposes.
Ken
quote:
Originally posted by Ken:
...We've also heard that the new Mobil 1 0W-30, 5w30, and 10w30 are essentially the same oil with different labels for marketing purposes.
Ken
They are not the same oil.
VaderSS, Pops, I found a good example of what I talked about earlier about comparing cold cranking and cold pumping specs. Here are some CC and CP specs from Schaeffer's #700 Supreme 7000 15w40:
CCS Viscosity @ -15°C cP (ASTM D-5293)
1,775
CCS Viscosity @ -20°C cP (ASTM D-5293)
2,804
CCS Viscosity @ -25°C cP (ASTM D-5293)
4,877
Mini-rotary Viscosity-TP.1 @-25°C cP (ASTM D-4684)
14,368
The cold cranking specs are shown at 3 different temperatures which is rare. Usually only the CC for the 15W rating is shown and that's at -20 *C. You can see that the dynamic viscosity increased about 1.6 times from -15*C to -20*C and 1.7 times from -20*C to -25*C. That's where the 1.7 comes from. The cold pumping spec will change similarly every 5*C.
Another interesting thing: This oil could qualify as a 10w-40 oil if Schaeffers chose to market it that way. It already passes the ASTM D-5293 test for the 10w designation and we can estimate that the CP viscosity will be 1.7 X 14,368 cP ~ 24,500 @ -30*c. So it will easily pass the ASTM D-4684 test for 10w also.
quote:
Originally posted by TooSlick:
Dr T,
The main difference between ACEA A3-02 and A5-02 is that the A3 has a tougher High Temp/High Shear spec...>3.5 for the A3 and 2.9 to 3.5 for A5
http://www.acea.be/ACEA/20020618PublicationsOilSequences.pdf
Ken
