Mobil 1 15w50 in the cold impressive
CO
Friend staying with me in CO has a Mazda Speed 3 and left it outside over night when the temp got down to about 10F, maybe lower. We got in early this AM to hit the gym and the car started right up, no fuss and no unusual engine noise what so ever. Dash read 7F at start up. The car felt and sounded as smooth as the 0w40 in my Alti SER during similar starts and RLI 5w40 in my Speed 6. Friend says hes started in much colder temps at the ski resorts, likely -10F often and no issues even then. He's been running the Mobil 1 15w50 since about 3K miles. Impressive to me.
Originally Posted By: addyguy
M1's '15W-50' is actually their 5W-50 with a different label - I'm convinced of it!
You could be right. The cold pumping and cranking viscosity of the 15W-50 is much, much lower than I would expect. I think it was as low as their 0W-40 is.
-39 degrees, dont get that cold in tennessee,,,I use 10w30 m 1, never a problem,,I think its good for -50 below f.
Well back in the days of temperature versus viscosity charts, before things got too dumbed down, a 15w- oil was acceptable for use down to 0-3F in general. And that was conventonal. A syn will give you some better pumping characteristics, and youre good in the range for the lube, so this is to be expected.
Does not mean that lubrication, flow and operation cannot be optimized further... Just means that the lube will work as expected. You proved the temp/visc charts to still be accurate!
I guess I am confused. Up here in Wyoming, we have cars running on 10W30, 15W40, 5W30, 5W20, yad, yada, yada, and they all start right up. People let them idle for less than a minute and drive right off. And mind you it is friggin cold up here, 17* as I type, and got below 0* last night, will get 45* below and more at times, and the cars will fire right up unless the cold kills a battery.
So what is the big deal?
I used Mobil 1 15w50 in wife's Caravan year round for 8 yrs and never had startup problems even -20F. Using 5w30 now though.
Oil choice is out of attempting to mitigate the DI fuel dilution issue and for track days. Warms the car gentle like most here before getting into the accel.
I used to use 20-50 and sometimes straight 40 all year long in the Chicago area.
My cars are always in good tune, so I always managed to get started.
But these were certainly NOT the best oil choices.
The 0w40's pour point is almost -60C. Significantly lower.
When I used Mobil 1 15w50 this year into winter it was pretty clear my truck started harder, cranked longer and the hydraulic tappet racket lasted much longer when compared to Mobil 1 0w40 (which I switched to). Sure my truck started on the first try but you could tell the oil was a bit too thick. Works great in the summer
Pour Point means nothing.
Mobil 1's '15W-50' is actually their 5W-50 with a different label - I'm convinced of it!
Which is of course the reason it is an advertised spec. I'm glad the ASTM wasted all this money developing these tests and the companies wasting all this money using thim.
MRV of Mobil 1 5w40 is 25,400 cST at -35C.
MRV of Mobil 1 0w40 is 26,242 cST at -40C.
It obviously has superior cold performance.
I cannot find an MRV data on the 15w50, so we'll have to suffice with these values and the Widman calc ones:
Mobil 1 0w40:
cST at 40C: 78.3
cST at 100C: 14
Density at 15C: 0.85
Mobil 1 5w40:
cST at 40C: 100.4
cST at 100C: 14.9
Mobil 1 15w50:
cST at 40C: 131.2
cST at 100C: 18.1
Density at 15C: 0.87
Widman's calc data:
Code:
GRADE -35C -30C -25C -20C
0w40 11308.5 6706.5 4135.4 2641.8
5w40 32292.6 17380.1 9818.5 5795.1
15w50 49794.3 26423.4 14724.5 8576.4
I know Doug does not put a lot of stock in the validity of the numbers below 0C, but it does give us some points of reference.
I have PERSONALLY experienced the difference between the 5w40 and the 0w40 in my own vehicle this winter. And to say it was substantial would be putting it mildly.
