Mobil 1 0w30
Illinois, USA
So, I've read many threads about Mobil 1 and it's plethora of grades... but what I can't seem to understand is why Mobil 1 0w30 doesn't get as much love as Mobil 1 0w-20 and Mobil 1 0w-40...
Is there something about Mobil 1 0w30 that makes it subpar in some way?
I've even heard that some folks use a 50/50 mix of Mobil 1 0w-20 and 0w-40 to make their own 0w-30. I've also heard that some say Mobil 1 5w30 has better cold flow specs than the 0w-30, which, I just don't understand.
What's so bad about Mobil 1 0w-30?
The reason I ask is because I've used only 5w30 in my truck ever since I've had it, and have been thinking about using 0w30 because IL winters get really cold. A few years ago in the winter, when I had 5w30 in my truck (IIRC, it was full-syn Mag 1 5w30), the windchill as -17*F (-27*C), and I went to start my truck. It started, but it whined and groaned and made all sorts of painful noises for a while.
I figured that I might a 0w30 this coming winter to see if it starts easier.
So, anyway, I guess my question is, would not Mobil 1 0w30 help make starting easier in cold winters?
~ Triton
Nothing at all sub-par about the product. 0W30 is not as popular as 5W30 that's all. I've been using Mobil 1 0W30 for a few years in an old Ford van that was originally spec'ed for 10W30. I think the oil is great, and read many good things about the product before making the move to it. I think it will serve you well, and offer better cold weather start ups if your temperature gets low enough.
Your engine doesn't care about wind chill. You are being dramatic with your example in an attempt to convince yourself you need the 0W. You don't. Mobil 1 5w30 will pump and protect in any temperature you will ever experience in Illinois.
Average winter temperature in Illinois is 28.3F, ranking the state as 19th.
Coldest ever recorded in the state is -36F. That's only one day. You should stay home in weather like that. What about your axle, PS and transmission fluids in that extreme? We won't even discuss the grease in your chassis.
Mobil 1 5w30 has a PP of -42, 0W is -50. What's your manual say?
I've been told that 0W30 isn't specified in any new cars in the US, and have to take that as fact.
0W20 is specified in new cars, and 0W40 also, but to a lesser extent, and more specialised applications.
So if those two ARE a common grade, and the 0W30 isn't then I can see the 0W30 being the oddball.
Practice originated in Canada, because the 0W30 Mobil 1 "wasn't available".
Then gained momentum, and when it WAS available in Canada got no respect as the blend has mystical properties.
All of the "advantages" that the 0W30 has are shared by the 5W30 at any sort of reasonable starting temperature...obviously the 0W is better at -35C and below, but between freezing temperatures and a hot summers day, the viscosities of the two are all but identical.
At -40C...you need all the "0W" you can get.
~ Triton
At the limits of pumpability, yep, the 0W30 will do a lot better.
At 10-20 below freezing, there's nearly nothing different.
There isn't a single engine sold here for which 0w30 is the recommended grade while there are many that call for 0W-20 and quite a few that require the certs that Mobil 1 0W-40 carries.
Mobil 1 Advanced Fuel Economy 0w30 is intended as an alternative oil for those engines for which a 5w30 or 10w30 is recommended by the engine manufacturer.
It also must be thinner than a 5w30 at very low temperatures since it meets the requirements of the 0w30 grade.
AFE appears to have more Grp IV in its basestock blend than does Mobil 1 5w30, for what that's worth.
This oil might lead to easier starts on the below zero mornings we've seen so many of over the past couple of winters.
For the same bucks as Mobil 1 5w30, there's no reason not to use it.
Not entirely true.
GM in the past has had a recommendation in the owners manual that if the vehicle sees extremely cold temps a 0w30 is recommended. My '02 Trailblazer and '04 Rainier had this statement.
Now that GM has gone to their DEXOS standard, Mobil 1 Advanced Fuel Economy is licensed so it would be a recommended grade.
I ran across a Castrol/Volvo recommended oil chart that specified 0w30 as the preferred oil for all Volvos from 90's thru 2005. This differs from the oils specified in owners' manuals, but oil technology has changed. We will be switching to 0w30 in a couple of our cars. I don't see how an oil can be too thin at engine start up.
Not entirely true.
My 08 Silverado owners manual says to use 0w30 if you expect to see temperatures of -20F or lower
You both have a point, but IIRC, 0w30 is allowed where temperatures below -20F are expected, not required.
5w30 remains the recommended oil.
I don't have a recent GM OM in front of me, but I do recall that 0w30 was allowed for an '08 GM product for which I recommended that the owner use AFE as did the M1 product selection function.
I switched to Mobil 1 0w30 a couple years ago. My youngest daughter was driving the Cirrus to college in Grand Forks, ND. She said it started much easier with the 0w30 vs Mobil 1 5w30 when temps went below zero. At home, I noticed the same thing. The difference seems to be more apparent at temps 0 and below.
I've used Mobil 1 Advanced Fuel Economy 0w30 extensively in the Expedition and it has the lowest consumption of any 30-weight I've ever used, which is no movement on the dipstick between 10-12,000Km changes.
Now, we actually DO get -30C up here on occasion, and at those temperatures, when I had Pennzoil Ultra 5w30 in the truck, I wished I had the AFE 0w30 in there as unaided, it providers a quicker cranking speed at that temperature. Keep in mind though, that's the CCS limit for a 5w, LOL!
Per my sig, I'm running Mobil 1 0w30 in everything right now. All's well and I only have to keep one oil in my stash.
Somehow I believe there's additional anti friction additives to get the AFE label. Just a guess though.
That or maybe the fuel saved on start up/warm up gives them a fraction of a mpg claim.
Mobil I 5w30 is a very good oil for wear protection. Take a look at 540ratblog.wordpress.com for a good discussion about motor oil wear protection. Mobil I 5w30 is rated 11 out of 159. Mobil I Mobil 1 Advanced Fuel Economy 0w30 is rated 83/159. Not a definitive treatise on motor oil but very well written. I myself have used Mobil I Mobil 1 Advanced Fuel Economy 0w30 in my Camry V6 since it became easy to find about eight or nine years ago. I tried Mobil I 0w-20 last winter just to see if start-up in very cold weather was easier using the lighter oil. I know, I know, 0w is 0w is 0w not matter what digits come next. Bottom line is it didn't get cold enough last winter in Nebraska to determine anything about the 0w-20 oil. I can tell you this, Lower viscosity oils did make a big difference starting a vehicle that had cold soaked all day in a parking lot near Craig,Colorado.
That that 540rats blog maybe well written but that's about it. Everything else is all opinionated and not credible at all. I did like all the vast VOAs of different oils though.
Some GM manuals state that one should use 0w30 (or synthetic 5w30) in temps below -20F....
The weather in So Cal is very mild all year, we don't need anything below 10W for winter months, because we almost never have anything below 30F, even below 40F is very rare about 3-5 nights a year at most.
With this in mind, I mixed Mobil 1 Extended Performance 0w20 with 0W40 (and Castrol 0-5W20 with 0W40) to get HTHS slightly above 3.0-3.1 at around 3.3-3.4 to use in my S2000 and E430. Both Mobil 1 Extended Performance 0w20 and 0W40 are long drain oils and both have higher percentage PAO, so that the mixed is shear stable to use in high rev engine of my S2000. The E430 recommended grade is Mobil 1 0W40(and others in MB list 229.5), but the car is rarely see rev above 3500-4000 RPM so I thin it down a little at around 3.2-3.3 HTHS.
I think it is safer to mix same brand and type, Mobil 1 with Mobil 1 and Castrol with Castrol.
