I've got a cheap "3hp" (from a 120v outlet
) oiled air compressor from Harbor Freight. Basically the same pump they use on everything.
I also bought the 3 year no questions asked extended warranty. ($16) I've already taken one compressor back that broke, and they came out and unloaded my old one...and then loaded a brand new one with no trouble. My warranty even started over again. The way the salesman explained the warranty to me when I bought it, was "basically even if it's just worn out you can bring it back and we'll replace it", so that's exactly what I plan on doing. At the end of my 3 years, I'll be back for another compressor. (if this one lasts that long)
Anyway....the manual calls for plain old 30w. I wouldn't use that if you paid me. Right now it has conventional 10w30 in it, and I'm considering changing to Mobil 1 0w20. Generally 20w oils are a big turn off for me. BUT, this compressor sees a lot of cold starts (90% of it's use) and I'm thinking maybe the 20w would help in the power department with the overloaded 120v motor? In my other non warranted chinese compressor I use 5w30 synthetic and noticed a drop in power consumption and temperature over whatever the factory fill was.
My concern is that I'd have excess wear with a 20w, but, then again that doesn't really matter if I'm not going to keep it...
I say Mobil 1 because it's the only 0w I can find, and, it's the only motor oil brand I've seen specifically recommended in compressor manuals...
