Very concerned about the comments in the report. Does this point towards en engine rebuild? How is this to be interpreted?
Thats the weird part. The Filter looks perfect, engine makes no weird noise, and the car runs perfect. Heavier oil sounds like a good idea.Nice car!
Total miles? Did you check the element for metal or anything else (cam guide pieces, etc.)? Any other symptoms?
I use heavier oils in ours; M1 5W or 15W-50. the 5W is Porsche A40 approved.
Yeah I am going to. do that and try a heavier oil next. Great suggestions.I would run another shorter interval and if the wear metals still warrant concern, I would do a compression check and maybe borescope the cylinders. Bore scoring comes to mind, but it is rare and your aluminum is low, but a check of the cylinders can't hurt.
May be time to talk to a good local Porsche indy....
Maybe but unlikely, the IMS doesn't explain the Cu and Pb, also there may/should be some debris in the filter element from the bearing and maybe the bearing seal if the IMS was on its way out. Also the very early and later (2005+) IMS bearings are less prone to issues.....yet.IMS bearing failure.
What?Driving it with some enthusiasm?
Shorten the interval to 3k miles, step up to a higher HTHS oil like a 5w40, and get another UOA
I would try this and see where you at.Nice car!
