I found in modern engines the recommended dose of either MMO or TC-W3 is a bit much and as too heavy a dose milage drops . So I started playing around with ratios in my Kia / Hyundai 4 & 6 cylinder engines and found a recipe of : MMO @ 960 : 1 and TC-W3 @ 1920 : 1 ratios mixed together . At these levels I did NOT lose any MPG so it tells me that the dose was not too much (your milage may vary and it is possible you can mix stronger for your engine application) . Here is a web site where you can plug in the above ratios based on your gas tank size : http://www.csgnetwork.com/oilfuelcalc.html I'd be curious to see what others have to say about their results are using the above as a base starting point ? Goal was to lube & clean entire fuel system including useage as a UCL . * For reference : MMO recommended dose is 320 : 1 and the LC1 forum recommends TC-W3 at a ratio of 640 : 1 to gas .
