I think this winds up my studies of MMO that started when I noticed such outstanding wear numbers on the first OCI run I had checked with it. RTS in gas means 8 ounces at each fill up, and the fill ups average about 16 gallons - giving slightly higher than the 4 ounces per 10 gallon concentration recommended on the label.
It seems that the wear numbers were slightly better with MMO in the oil, but the TBN dropped faster. It seems that the TBN dropped a little faster with just MMO in the gas, too. I can't tell any difference in the oil usage with or without MMO.
I'm through experimenting with MMO in the oil. Despite what appear to be very minor differences, the wear numbers look excellent with just the Rotella T synthetic in the sump. I will probably still use 20% MMO in the oil for an OCI next time I buy a used car just to be sure it is clean inside - which is the way this saga started. I will continue to use it regularly in my gas.
Note: The 5000 miles in the comments for the last run is an approximate number. I left the oil in after the previous sample, added 1 quart of MMO after another 1000 miles or so, and then took another sample at the indicated mileage of the last test.
