Originally Posted By: Char Baby
My wifes '01 Lexus RX-300 throws a CEL every time I have used MMO(proper dosage)so, I don't use it in her car but...
Are you using the "maximum" dosing of 4 oz. to 10 gallons...? If so....try lowering the dosing to 3 oz. to 10 gallons....see if that makes a difference....these newer machines and their picky codes....hehe. I find it hard to believe the ECU would "notice" the 4 oz. in 10 gallons of fuel...unless it's a bad measurement at the pump? I've found my girl friend's 4 oz. Acetone bottle works great....predosed and ready to go right at the pump
No need to mess with the oily MMO bottle at the pump, chugging away, and checking the level at the hash marks on the bottle, etc.....just keep it pre-measured....the 4 oz. dose works great for my typical fill of 9-12 gallons.....depending on how low I drive the tank
But like they say, "your mileage may vary"
but definitely try "cutting down" the dosage, to 3 oz. instead of 4 and see if that helps any....
This engine doesn't seem to like anything extra in the gas tank at the regular/recomended strength, even fuel system cleaner(s) such as Techron or Regane. Although these FSC do clean, the CEL still comes on with'em.
I'm thinking, that I don't really need any MMO in the Lexus. All the code is telling me is; that one of the sensors is noiticing that something is different/out of it's range of measurement. The next tank of gas takes care of the CEL.
Yes, I could try MMO at 3oz/10gal gas. But I'm not sure that I want to at this point. I want there to be enough MMO mix in the gas to at least do something along the lines of cleaning/lubricating. Otherwise too little of the MMO could be just a waste of the MMO, if it's not enough to do anything!
For this particular Lexus, I don't know what amount would be considered too little(I already know what is too much)...Because I have never noticed that the MMO made the engine run better in terms of smoother/quieter of better MPG.
On the other hand(OTOH), I have often overdosed carburated engines(beyond the recomended dosage) with MMO and they seem to love it! Overdosed meaning...double the amount recomended(YES, double!)
It might just be the luck of the draw in your case. I've OD MMO more times than I can count with no problems. If you care to experiment cut the dose or just stop using it all together. You really don't any other choices.
