Originally Posted By: ahoier
Though MMO _is_ compatible with full synthetic oil......I don't support the use in synthetic oils
Especially, not since MMO themselves recommend a mere 3,000 mile OCI, when the MMO is used.....
Something to do with the detergents that MMO contains, you basically don't want it in the engine longer than 3000 miles......
Now, something I _have_ heard, and could partially support, would be adding the MMO at say, the last 3000 miles of an "extended" full synthetic oil change
So, say you run 5k OCIs, add the MMO at 2000 miles........since they recommend dumping the oil in 3k, you'll be right at 5k
BUT, on the other hand, I've also heard some people say that they believe the MMO does "better" cleaning when used in "fresh" motor oil.....
Soooo......you could perhaps use the MMO as the last 3000 miles of an extended oil change, then when you change the oil, add fresh MMO with your "new" motor oil.....just don't OVER dose the engine with it....MMO themselves states 1 quart of MMO in a 5 quart engine.....but I like to shy down to a pint.....and yes, I've seen seen good results (extremely dark oil drains at 3k......).
But yea, you're best bet, is to just wait for your next OCI, get some cheap SuperTech, Quaker State or Pennzoil conventional, and add the MMO with the cheap conventional oil
+1 Nothing at all wrong with adding MMO to synthetic oil for the last 3000 miles of an OCI, as you stated just don't over fill it. I think the 3000 mile logic is sound, I mean how long do you want dirty oil in your engine after a clean up job? Using it with something like Pennzoil conventional for 3000 miles would be the way to go, unless your car calls for synthetic oil. If that's the case use the synthetic oil, and either run the mix for 3K, or remove a qt of oil at the 3K mark, and add the MMO and complete the interval.
