First post from a new member. I'm putting a vintage (1930's) vehicle back on the road and would appreciate the forum's collective wisdom on engine oil.
The engine is an air cooled, in-line 4 cylinder that shares its oil with the transmission. The clutch is dry. The engine has a crude, wire mesh sump oil filter so oil changes will be made at 500-1000 mile intervals. The cost of oil isn't really a consideration as the vehicle won't be used on a regular basis.
The factory recommendation was for straight 20W in the winter (40F and to below freezing), straight 30W for summer, and straight 40W for continuous operation in >80F temperatures. Of course oil technologies have come a long way since the 30's.
I've spoken with someone who has has owned and operated several identical vehicles for decades, and he uses 10W-40 year round in temperatures from about 40F in the winter to 95F in the summer. Based on the factory specs, it seems like 15w40 would be a better choice in an off-the-shelf product, but he hasn't experienced any ill effects using 10W-40. My ambient operating temperature range would be about the same. I was explicitly warned not to use straight 40W in cooler temperatures as other owners have experienced big end bearing failures with that combination.
Based on the factory specs, it seems like a low end of 20-25 and a high end of 35-40 would be optimal for my use, but those are not available off the shelf. So I'm wondering whether I could get there by mixing 15w40 and straight 30W or 40W?
Another reason for wanting to go with a mixture is that the engine was probably operated with non-detergent oils for a long time, and I'm a little concerned that switching to a detergent type multi-weight oil will suddenly release sludge deposits. Whereas if I mix a non-detergent single weight and a detergent multi-weight, the overall detergent concentration will be lower such that sludge deposits will be released at a slower rate, which can be accommodated with very frequent oil changes during the first 1000 miles or so.
