Mixing leftover oil quarts together
Originally Posted By: ARCOgraphite
Read the patent application for the low phos add packs and then call it fear mongering. Ive posted the links before. Do your own research. Dont ask those whom are unqualified to give you an answer - just because thay are members of an oil board - that just builds the "Idiocracy".
from patent 7183241
As is known in the art, additives are used in lubricants to perform numerous functions. For example, some are antioxidants, some are friction modifiers; and some are extreme pressure agents. Indeed some additives perform more than one function. Also as is known in the art, additives will lose their effectiveness if they are improperly combined. Therefore, extreme care must be exercised in combining various additives to assure both compatibility and effectiveness. For example, some frictionmodifiers affect metal surfaces differently than antiwear agents do. When both are present, friction-reducing and antiwear additives may compete for the surface of the metal parts which are subject to lubrication. This competition can produce alubricant that is less effective than is suggested by the individual properties of the additive components.
Accordingly, the components of a gas engine lubricant need to be selected to meet the specified ash level and to provide, among other functions, a high level of oxidation and nitration resistance. Whether selected components and their amountscan be balanced to meet desired specification is not a priori predictable.
Although the patent app may have merit in itself, it seems to generalize and extrapolate without giving any specifics.
Really, it's just asserting theory without a foundation of facts. It's not really relevant to commonplace API spec oils either, whose additives are indeed compatible.
Let's see just one example of additive clash...in the engine, not on paper. A bad UOA from a mixed oil would be a start.
Originally Posted By: Gary Allan
Just look at it as "the best of" ..or "greatest hits" of your oil usage history ..all wrapped into one sump.
Hahaha! The only thing that would make it complete would be if the oil was branded "K-Tel"!
Agreed. Anyone here have a series of UOA who is feeling lab rattish? Picking the concotion will be fun too!
Put 5 different oils in as long as they are sm rated and close to the same weight i dont see a real problem..
I know someone that has a 1993 ford truck with over 275,000 miles and he just adds oil of any kind when its needed... I told him he needed an oil change and he said nooooooooooooo cant do that!
The oil plug threads are shot and he spot welded it a couple of years ago so it cant be taken off..That truck burns a little oil and he puts in anything he has on hand... He changes the filter every year or two (his own words)
Truck still runs and is abused most of the time..Amazing!
i have a jug of leftover 5-20 and 5-30 mixed with 3 different brands...i am still going to use it sometime
oil dude, that is a funny story but sad to say not uncommon as far as just adding oil haha....what surprises me is that he even bothers to change filter..my friend did that on his "turbo" (not realy) s10 chevrolet, he would just add oil when it started knocking, same with his ranger...engines kept running for the few years he ran them...50k on his his maint "schedule"...my dad did same thing on his 1980 F100, just added oil and engine kept going for some reason
So who's up for a frankenbrew used oil analysis test? Where did everybody run to?
I would kindly do it but I dont have a used oil analysis history. Anybod y here with rigorous used oil analysis history up to the challenge?
Lets see 1 qt each:
Pennzoil Platinum, Valvoline SynPower, Castrol Syntec, Mobil 1, Quaker State HorsePower.
Or:
Valvoline conventional, MCSS, Pennzoil conventional, Motorcraft 5000, Castrol GTX
or any random combo thereof.
I have mentioned it here in a number of posts. I mix all of the time. I did it years ago when I was young(early 70's) and didn't have much money. Today I mix 2 qts syn w/ 3 qts dino. Not trying to be scientific or to outsmart the oil engineers but until discovering BITOG, I would never have used syn oil. The only reason I use syn at all is because of the "Products, Rebates, Promotions" section when I find syn oil on the cheap, dino too! I now have a stash of oils(syn/dino) often between 50-80 qts. I mix syn and dino, different brands and wieghts. Never an oil related issue! EVER!
I have a current batch brewing back here in the lube shop. The container is a Castrol 10w30 with whatever left overs were in it from that oil change. What I have started to do is use that as my collection container. When ever the weekend hits, I will take the nozzle/cap off of the containers I use to fill vehicles with my bulk oil and let them drip off into the Castrol container. During the week I will take whatever quart bottled oil I use and let the quarts drip off into it. Let me see if I can recall what all is in the bottle currently....
Castrol 10/30
Royal Purple 5/20
Formula Shell Full Synthetic 5/30, 5/20, and 10/30
Motorcraft 5/20
Quaker State 10/30
SuperTech 10/30
Pennzoil Platinum 5/30
Cam2 5/30, 5/20, 10/30, and 15w40
Rotella 5w40 and 15w40
Mobil 1 10w30 and 5/30
I think that's all of them in this batch so far.
Castrol 10/30
Royal Purple 5/20
Motorcraft 5/20
Quaker State 10/30
SuperTech 10/30
Dang!
You have out-done me by far... and i really went -BERZERK- with my car's Oil Blends, seems i get a New Head on TOP of a Clean Engine. :D
Castrol 10/30
Royal Purple 5/20
Motorcraft 5/20
Quaker State 10/30
SuperTech 10/30
Dang!
Yeah, well it helps when you own your own shop... lol!
