Mixing grease
After reading grease compatibility chart, I have two questions.
1. If I mix aluminum complex and lithium complex grease, will it safe for rubber part on my motorbike?
2. If the mixture of aluminum complex and lithium complex not recommended, can I use H-1 complex calcium sulfonate grease, also for my motorbike?
IMHO, I would always avoid petroleum based grease on rubber parts as the oil can and will casue rubber to swell and may even cause it to swell to the point it will crack. If you need to put grease on a rubber part, use a silicone based grease such as dielectric grease or any othr silicone based product.
Mainly for cvt bearing, cone steer and wheel bearing.
