Who said an engine will blow up though? Also that’s a pretty low standard to set. That would be like judging the food solely based on the fact it didn’t give you food poisoning.Engine didn’t blow up, wear levels were fine, id be cool as a cucumber seeing that report![]()
But lots of oil remains inside and engine at oil change.
having residual oil in the sump is one thing....meaningfully mixing brands is another.
You sir have been awarded the “BITOG Of The Day Award” just for mentioning the long venerated and coveted, “Green Elixir.”Long term members here will remember that when I would switch over a car to German Castrol 0w30 I would do something that I called the Patman flush. I would drain the old oil for about a half hour and then I would add 2L of Castrol 0w30 and idle the engine for maybe 30 seconds. Then I would drain that out for about a half hour. This way the engine would not have all that much of the previous oil left behind. I mostly wanted to do this because I wanted to see how well this oil held its viscosity so I didn’t want any of the previous oil’s viscosity to be a factor. GC 0w30 was such a radically different oil that it was a good idea for it not to get mixed with other brands, especially when running it for longer intervals right away. I don’t do this anymore but I do think about it from time to time.
But it’s always Okay when it’s 20-25% EC30For the guys that say absolutely no mixing; As mentioned by @BrendanC above, is this your believe for top up oil as well?
You're 1000 miles from home on a vacation road trip and you discover your 5qt sump is 1qt low. Are you driving from store to store trying to find the exact oil you have in the sump? That is beyond BITOG silliness that being the case and I've been around as long as the "Patman Flush".
I believe most of us BITOGers agree that we'd prefer not to mix different brands of oil on a fresh oil change. I know with my fleet I've done it many times when my stash of whatever was a quart lower than I thought and I had to top up with something similar.
There's a chasm between the relatively reasonable position of "I try to avoid mixing when possible" and "I'm Slim Shady the Super Chemist and I'm making the ultimate oil by mixing 2 quarts of Synlube with 2 quarts of City Star and 2 quarts of Supertech, I call this the 2/2/2 Super Combo and my Blackstone UOA tells me it's the BEES KNEES!!!".For the guys that say absolutely no mixing; As mentioned by @BrendanC above, is this your belief for top up oil as well?
I just find the closest WalMart. That's where I buy oil for OCI's.For the guys that say absolutely no mixing; As mentioned by @BrendanC above, is this your belief for top up oil as well?
I’m pretty confident in saying that most people on here who are embarking on a long road trip would have checked the oil and topped it off before leaving, so they would not find themselves in a situation like this. And if they had a vehicle that was a known consumer of oil they would have an extra quart or two in the trunk for those trips.For the guys that say absolutely no mixing; As mentioned by @BrendanC above, is this your belief for top up oil as well?
exactly right. every fluid gets checked and topped off in any of my vehicles before leaving for a road trip. both accords have a quart of HPL PCEO 5w30 in the trunks just in case. my pickup has never burned a drop of oil so i just verify level and take off. if your vehicle burns that much oil it may be better to buy more than you need when you’re buying oil change supplies and keep the extra in your trunk.I’m pretty confident in saying that most people on here who are embarking on a long road trip would have checked the oil and topped it off before leaving, so they would not find themselves in a situation like this. And if they had a vehicle that was a known consumer of oil they would have an extra quart or two in the trunk for those trips.
Even though my Civic doesn’t consume much oil (about half a quart every 5k) I still have extra oil in my trunk. When I buy a 5qt jug I only need 4.5 quarts for the oil change and the other half quart gets saved for later.
I was looking for more of a yes or no answer. This is BITOG. Silly me!I’m pretty confident in saying that most people on here who are embarking on a long road trip would have checked the oil and topped it off before leaving, so they would not find themselves in a situation like this. And if they had a vehicle that was a known consumer of oil they would have an extra quart or two in the trunk for those trips.
