Mix Proylene and Ethylene?
why? other than PG is not as good as EG for freeze protection but PG is also not Toxic for kids and birdies.
bruce
What happens if you mix 2 different grades of ethylene glycol? I just checked the label on the Prestone Low Tox I have on hand. It says nothing about being careful not to mix with ethylene glycol. I don't know what it is comparable to, I suppose the plain old yellow jug Prestone.
I do feel that when I soon dump the Dex-Cool that came in my 02 Cavalier, that I do several drain/flush cycles to remove the last trace of Dex-Cool before adding Low Tox or any non Dex-Cool.
Remember when all there was was permanent antifreeze and the alcohol that boiled away?
Conventional wisdom is they do react. I had a shop put a radiator in my dads old dodge van.
I told them not to top off with EG. It had the old Amsoil PG formula.
They did and I could see the reaction after a couple of months. The new Amsoil PG says it is compatible with just about anything. It's what
I run now.
I would not add the two together unless one of them says it's compatible. Even then keep an eye on the system.
