Originally Posted By: ZeeOSix
Originally Posted By: UncleDave
Particle removal becomes worse as the particles reduce in size in a non linear fashion - not 1-1
This is basically how the different types of media filter. Particle micron size on x-axis and filtering efficiency % on y-axis.
The reason is no other combo has proven to keep the sump in tact over 3 filter and 30K.
What other claim out there matches this much less tests out independently?
Just because nobody else has "proved" it doesn't mean there are other very efficient oil filters out there that would give the same results as the Microgreen. If the Ultra does 80% @ 5 microns (basically the red synthetic curve above) I'm betting it's going to give indistinguishable performance compared to the Microgreen.
Thats a great chart- with one filter on the Axes- not two- overlay the MG micro disk on top of that and see which covers a wider range of capture
Was it you that coined the term- strong performance produces strong claims? Dont recall but you were in the discussion (adding value as usual I enjoy your posts)
We were chatting 4548 -12 and the claim was MG must not be good because they dont print it. ( or dodge it)
If a company can't do well in something they dont publish the claim - - conversely when a company can do something they publish it through a claim.
If anyone could match their claim they'd have done so for years now, but they obviously cant.
Im betting if one could add a particle count as part of the testing it would be notably better than a single stage.
Not that a good single stage isnt good- they are great - especially per dollar- but a 2 stage has unique advantages a single stage just cannot provide.
UD
