Microgreen and 2012 Honda Pilot Experience
Honda does or did have some peculiar ideas of managing issues. My friends era mdx also pilots would disable the 4wd if you threw any engine code or if your voltage was down a hair. The system controlling the awd operated on very low power so was sensitive. The main problem was having the adjust the lifters/valves was needed to keep the light off for good. You could reset the codes and be good for a varying period of time. Ideally these issues should be taken care of if you follow the maintenance schedule to the t. But they're just a little overly cautious by disabling functions such as half an engine or 2 of the wheels power.
Originally Posted By: AirgunSavant
I have used so many 101-7's that you could fill up a oil drum with.
No issues! That said I dislike drama myself so I won't use what I fear. Why bother?
Originally Posted By: Bottom_Feeder
I've been leery about using the 101-7 I bought for my Accord since the louvers seem almost closed. This may be what keeps me away from it for good.
Same thing. Have a bunch of used 101-7's in a box. Zero issues.
If I though it was causing an issue id simply run something else.
Its too small for my long acre to cut or Id cut and paste for everyone.
UD
