Quote:
Funny thing. For years I have proclaimed the advantage of using lighter engine oils in OPE. Obviously, a 15W40 oil requires more energy to move around in a splash lubricated engine, and burns more fuel to do so. About three weeks ago, I set out to prove this.
Your engine was already "hot", so the oil in the 2nd "test" had some "pre heating". Do your test in reverse order (viscosity wise) and see what happens.
My lawn vac has a 4.5 hp Tecumseh engine. It had EXXON 5W30 dino oil in it. I filled the gas tank carefully, noted the time, and cranked it up. It ran almost exactly 45 minutes and stopped. I drained the hot oil out, giving it a long time to drain. I refilled with Pennzoil 15W40 oil, and refilled the fuel tank. Cranked it back up and waited. At about the 40 minute mark, I begin to pay close attention, as I was sure it was about time for the 15W40 to make the tank run dry. But, no. It continued to run, and run and run. It passed 45 minutes and continued to run. Finally, at 49 minutes it ran out.
I could not understand this. I am going to repeat this test using new 5W30 (the 5w30 I drained had about 20 hours on it).
