Methanol and Ethanol compatibility wit MMO?
South East Asia
Just wondering if the methanol and ethanol compatibility with MMO is different ?
Just read that MMO is not compatible with methanol, wonder if it is the same case with Ethanol.
are you talking about straight ethanol like they use in injector systems or the blends we get in gas stations?
because the methanol incompatibility is talking about the injector systems
My question is those ethanol from gas station, that is supposed to be pretty diluted in E10 or E15 but just wondering if even small amount would cause problem due to incompatibility with MMO
Not a problem with gasoline blends as long as there is gasoline. If you were running 100% methanol, don't use the MMO.
