Metal to Concrete adhesive recommendation?
I have an aluminum sign that I need to attach (glue) to concrete block, and I don't want to drill holes in the concrete. Google AI says Loctite Epoxy Metal/Concrete is what I want. What say you all?
This polyurethane based construction adhesive will be a permanent bond for that sign. Holds up well in the outdoor environment.
I agree with Google AI, and yes, make the bottom of the aluminum as rough as possible. The "glue" should have a thick consistancy, almost like putty.
JB Weld might work too.
