I am working on some security lights. I notice they take a long time, 15 minutes? to come on. Should I be expecting to have to replace the ballasts soon?
I found a mess today. I had changed the bulb the other day in one, and it still didn't work. I decided today would be a good day to get back to it. It turns out, the ''new'' bulb wasn't any good either. Before I found that out, I discover the licensed person that took money to instal it, ran 8' of 2 conductor w/o ground SJT from a box out through a brick wall and into the box. It is only a 85 watt unit, so the wire was heavy enough. Instead of the 1/2'' conduit thread, the cast exterior box had a 3/16'' X 1 1/2'' slot. How are you supposed to seal the feed to that?
