Originally Posted By: drtyler
I've got an '89 Lincoln Town Car and want to change the ATF fluid and filter soon. It has the Ford AOD transmission. I was going to use either Motorcraft Mercon V or Valvoline Maxlife, but I found some discussion at a different forum that stated Mercon V fluids were not good for the clutches. This could have been the original formula of Mercon V, which may have been updated, or maybe it was just not factual. I haven't seen or heard any other reference to this.
Has anyone here had issues using either Mercon V or Maxlife in a Ford AOD application?
I like the CASTROL MERC V... Max Life Im sure is good but it a multi vehicle ATF...
Read specs of Castrol V.. I like how its CERTIFED and APPROVED by FORD.. MAX LIFE is not it just says suitable for Mercron V... Not even recommended.. just suitable.
I would really go with Castrol.. read the specs and info and you will do the right thing.
Read the specs
Product Data – Castrol Transmax Mercon V ATF
PRODUCT DATA
Castrol Transmax™ MERCON® V Automatic Transmission Fluid (ATF)
Castrol Transmax™ MERCON® V Transmission Fluid is for use in most Ford vehicles.
Features and Benefits
Enhanced friction durability provides superior transmission life and promotes smooth shifting
Exceptional thermal protection guards against transmission wear
Certified and approved by Ford for all cars
and trucks that require
MERCON® or MERCON® V
Do not use this ATF in applications calling for MERCON® SP or Type F
Warranty and Protection Requirements
Exceeds all passenger car and light truck m
anufacturer’s warranty requirements for vehicles,
transmissions or power steering service where a
MERCON® or MERCON® V type ATF is specified
Industry Specifications and OEM Approvals
Meets or exceeds Ford MERCON® V and Ford MERCON® Requirements
MERCON® V Approved and Licensed by Ford Motor Company
Typical Properties*
Test Method Typical Results
Viscosity at 40°C, cSt ASTM D-445 35
Viscosity at 100°C, cSt ASTM D-445 7.4
Viscosity Index ASTM D-2270 186
Color, Typical ASTM D-1500 7
Appearance Red
Brookfield Viscosity at -40 C, cP ASTM D-2983 9,800
Pour Point, ºC (ºF) ASTM D-97 -35(-31)
Flash Point, °C (°F) ASTM D-92 180(356)
Specific Gravity, 60°F ASTM D-1298 0.862
Pounds per Gallon ASTM D-287 7.17
