Didn't certain W210's have a bad harmonic balancer?
You are right, I think it was an issue with the M112 V6, mine has the M104 straight 6. The issue is not rpm related, it's not the torque converter either.Didn't certain W210's have a bad harmonic balancer?
There's no abnormal play anywhere in that area, i think that the issue comes from the front of the car as it is not fast enough to be a driveshaft issue.have you checked the rear diff/final drive? check for enough lash especially
Just spent two hours taking a good look at everything and at least one tie rod got slightly worse, there's a bit of play in the front bushing of lower control arms as well, would that be enough to cause this issue? I have to replace them anyway.
The other thing that seemed weird to me is that i couldn't tighten the wheel bearing more, i tightened the as far as i could but the bearing was still a bit loose.
I definitely feel something in the steering wheel but i'd say it is diffuse and comes from the front of the car and not really a steering wheel shake such as a missing weight. I am not too concerned about the rear axle, the two driveshafts usually start to fail at mega miles on those cars, quite unusual.
You have a issue with the wheel bearing, you do not tighten the bearing nut as far as you can there is the MB spec using a dial indicator to achieve 0.01-0.002 mm end play but you can backyard it and tighten it just snug and back it off slightly. If you are tightening it that much and it still has play suspect a bad bearing. Yes it can cause vibration as can a bad LCA bushing.You are right, I think it was an issue with the M112 V6, mine has the M104 straight 6. The issue is not rpm related, it's not the torque converter either.
Thanks, i will replace both front wheel bearings. Even as tight as the nut is right now i don't even need a dial indicator to tell me that it is too loose! The grease was nice and green around the nut but brown and nasty inside the bearing itself.You have a issue with the wheel bearing, you do not tighten the bearing nut as far as you can there is the MB spec using a dial indicator to achieve 0.01-0.002 mm end play but you can backyard it and tighten it just snug and back it off slightly. If you are tightening it that much and it still has play suspect a bad bearing. Yes it can cause vibration as can a bad LCA bushing.
Make sure the back of the wheels where it mounts to the hub and hubs are clean and free of corrosion.
Do you an app to recommend? I'd like to try.Use your smartphone with an app to detect the vibration frequency. That will reduce you to specific components at that frequency (drive shaft, wheel) and go from there.
I'll replace tie rods and tie rod ends, LCA bushings and bearings since they are bad anyway and finger crossed the vibration will be solved but my hopes are low. What is strange is how well the car rides otherwise on roads that are not the best.
What speed where you at? I use https://play.google.com/store/apps/details?id=com.morganandwife.vibration to show me the dominant frequency.Thanks, i've just found another similar app and on my short drive the peak frequencies were in the 20hz ballpark at speed but it was a very short drive.
That’s the important thing. Be at constant speed, know revs/mile then you know what the once per rotation vibration source from a tire would be.What speed where you at? I use https://play.google.com/store/apps/details?id=com.morganandwife.vibration to show me the dominant frequency.
Hz*60 = RPM then you can figure out what spins at that speed.
That's the exact app i am using!What speed where you at? I use https://play.google.com/store/apps/details?id=com.morganandwife.vibration to show me the dominant frequency.
Forgot the keep you posted but it might help someone. Guess the cause? First shop did a poor job at balancing my wheels. Second shop did even worse which resulted in 20 grams of inbalance on one wheel, 10 grams on the other. Third shop, i had to stand next to the guy balancing my tires and had to insist to set the wheels to zero grams of inbalance after hearing him say that 10 grams is not much and is acceptable.
In the end is was all down to laziness. Now the car is smooth even at 200 km/h (on german roads).
