Originally Posted By: Artem
Originally Posted By: spasm3
I fill mine, when i had a sideways mounted screw on filter, i would put enough in to wet the element. If i cant fill the filter i would also bump the starter several times before letting it fire up. Not necessary but i just like filling the filter. What i do think is important is wiping the cut threads of the filter with a cloth or paper towel. Make sure you don't leave any lint behind but i always get silver looking metal dust off the threads.
The oil filter is mounted at an angle in my 98 Toyota Camry V6. It's pointed at the 8 & 2 o'clock positions with the outlet pointing down and I still pre-fill it each and every time. The 1MZ-FE engine rattles and makes a lot of noise upon initial start up, after an oil change. With the filter pre-filled ever so slightly (I fill it to the top quickly and within 60 seconds, all the oil is soaked into the filter media) I'm able to screw it on without dripping a drop.
Originally Posted By: KCJeep
I used to but I quit doing it. All I seemed to be gaining was making a mess. I don't even get start up noise at an OCI with a dry filter, why bother?
All you guys that mentioned making a mess while doing something so simple as pouring a cup of oil into the filter are hilarious...
I want to see how you spill oil all over the valve cover while pouring oil into the engine.
I want to see how you spill oil all over while pouring the used oil from the drain pan, into the jug.
I want to see how you spill oil all over the place as you pour used into into the recycling tank at the auto parts store.
I want to see how you accomplish simple every day tasks like pouring coffee into a cup without spilling it because you guy make it seem like it's SO HARD to pour oil into the filter without dumping the quote 5qt jug all over the drive way.
come on now!
No silly, spinning a pre-filled horizontal filter onto the vehicle simply made a mess.
