MC FL-820S Cut Open
Originally Posted By: sayjac
^^^^^Other than you quoting part of my post, no idea what your post means or is referencing. Also don't know what "clips" are. Seam? As has been noted by not only myself, there's little or no chance the extra leaf spring would be any factor other than as stated in my post. And, the OP noted no issue with said filter. On a previous post someone alluded to shock regarding this occurence, yet seemingly not so much over the obviously loose element of the recently posted Ultra. Seems ironic to me, that's all.
And fwiw, a filter with an extra leaf spring has been posted previously on this board.
Basically, since you didn't use a name, I was asking if you were talking about me.
The rest was Friday afternoon rambling and philosophizing.
Oh well all you had to do was ask. Negative. Your comment fas as I could tell dealt with the concave closed endcap, no bypass. As said here, standard for a majority GM applications. Have good one.
