I would probably go with the Rislone concentrate only because I have used it and seen no issues even when used long term, if you said there are a few drops under the car from the rear main seal I would go with the Bars.
If you are not seeing anything under the car, its not a real issue at this point, IMO the best course of action is to do what you can so it doesn't worsen. The last thing you want to do is blow the seals up like an elephants trunk, the seal will eventually shrink and possibly cause a real leak when it does,
