Mazda CX-5 Skyactive Transmission fluid?
Colorado Springs
Hi, I'm buying a 2016 Mazda CX-5 AWD. The manual calls for Mazda Type FZ fluid, but I read on another forum that the newest model Skyactive transmissions spec a newer fluid that is backwards compatible and better than FZ fluid.
Does anyone know if there is any truth to this??? Thanks!
Nope, Type FZ is what you need. I have a thread on the DIY somewhere here.
And welcome back!
And welcome back!
Video of a 2014 cx-5 change. Only issues i see are
1. He used scotchbrite to clean the pan lip. I keep scotchbrite away from trans and engine internals, although he said he cleaned it with brake parts cleaner.
2. He used too much gasket sealer, its oozing out a bit.
Overall shows the basics of how to do it.
Ok, thanks guys, and thanks Critic! It's been a while.
I'm thinking I'll skip the filter and just do periodic drain and refills. I read on a forum where it took a guy 3 hours to scrape the old silicon off the pan and transmission...
Drain and refills are just fine. No need to remove pan.
Thats what i'm going to do. I think i will do the first at about 30k and every 30k. Maybe the pan drop and filter change at 100k. At our current rate that will be a while.
