- Joined
- Aug 3, 2024
- Messages
- 239
It's at least 10 years old and has been rock-solid reliable, until today when I found the ice bin nearly empty. The water flow is fine through the dispenser and the filter is maybe a month old, so supply isn't a problem. The auger and everything else seem to be working normally, the tray simply doesn't refill. I pulled out the bin and felt up inside, there was a single row of cubes upside down on top of the tray which I removed hoping that was the problem, but it didn't make any difference and the tray was empty. The bail that detects the ice level moves freely and nothing appears to be jammed up in any way, no rogue cubes stuck where they don't belong.
I cut the power for a few minutes hoping a "reboot" would help, still nothing. For whatever reason the valve to refill the tray with water just isn't activating, everything else operates normally.
I'm usually pretty handy with home repair but icemakers are a bit out of my wheelhouse. I'd hate to spend a fortune on a service call for such an old unit but I also want to avoid firing the parts cannon trying to fix it myself, and searching the internet didn't tell me anything I didn't already try. If anyone here has any advice on where to begin it would be highly appreciated.
