maxlife atf
The fact your own transmission rebuilder/replacer couldn't tell you why it failed is suspect to say the least.
You really should just give it up.
That specific trans is KNOWN for having weak sun shells and that is more that likely what did you in.
Quote:
And it is everyone else's right to tell you to shut the [censored] up.
Every shred of validity that your complaint about max life is destroyed by your crybaby complaining. Shut up.
Seems like a lot of fanbois here for Ashland.
....or the guy did a great job and it was cheaper just to R&R.
Originally Posted By: Oil Changer
The best part is the Zinc. Dex IIIH doesn't have it. Ashlond said MaxJunk don't have it yet when the PQIA tested MaxJunk, Zinc showed up. When when I wrote back to Ashland about that, their return letters abruptly stopped.
Just as an aside, I forget a couple of the details of your experience. Did you get your MaxLife ATF tested after your issue? I thought you did, but I could be mistaken. Was anything else out of whack besides possible additive issues?
Direct from the "epic" original thread (someone posted a link to the whole post in this thread):
"I contacted Ashland. They sent an oil sample kit. I sent the sample. This was their response:
"Results indicate that sample formulation is in compliance with the additive package specifications for the Valvoline MaxLife Dex/Merc ATF. Sample does indicate a significant increase in Iron, indicating potential wear inside the transmission, however as a result of the Valvoline product not showing any signs of failure, this wear has been attributed to the older fluid in the system. This is also evident from the detection of Zinc in the sample, as Zinc is not an additive utilized in the Valvoline MaxLife Dex/Merc ATF product.
The sample does not indicate any signs of failure and Valvoline stands behind the use of our Valvoline MaxLife Dex/Merc ATF product for use in this particular application 100%.""
We know from various outside entities that MaxJunk most certainly does contain Zinc. Other than the obvious, before the fluid change, the transmission operated perfectly.
I'm not complaining, crying, or whining. My mistake for not following my instincts and using what has worked for me for 30 years and allow myself to get swept up in the BITOG fan boy oil of the month club. I've moved on days after it happened. That doesn't mean I'm going to sit back and pretend it didn't happen either. There's an ignore button for a reason. I suggest you use it; you'll be happier. Spare me the tough guy attitude, you failed.
How? Because it is my God given right as a free, flag waving American and veteran to do so if I wish? If you can't understand or accept that, continue to disregard my posts. My life will churn merrily along either way.
Originally Posted By: 901Memphis
How can you bash an entire brand when something like Synpower can produce such good UOAs?
https://bobistheoilguy.com/forums/ubbthreads.php/topics/3107221/1
I don't even like Valvoline particularly but it's not like it's Lucas!
You don't understand the power of the Internet or the psychology behind it. I'm just planting the seed. It was all explained in the original post that is linked in this thread. I've disclosed everything and hid nothing. Besides, pretty much everything in my life is more important than trying to gain respect or care what people on an oil related forum think of me.
For the record, I did not start this, nor do I start posts just to bash Valvoline. I was always more than polite about my objection to MaxLife but a few members DEMANDED (LOL!) that I elaborate, so I did and here we are. If you closely read the original post that is linked in this thread, you can even spot who a couple of them are.
Originally Posted By: BISCUT
I can understand your opinion on MaxLife ATF and your correlation with it causing your AT to fail. Got it. And I can also understand how you would never want to recommend their other products. But to bash everything they make takes away from your argument...a lot!
You are welcome.
Thanks for the tip
Maybe getting out of Detroit will improve your attitude.
Amen, brother! Amen!
You are far from polite, arrogant and condescending is more like it. You also say there is no way it was user error. Considering your arrogance can we believe that? Is it possible you did do something wrong? I think so, [censored] there is always a possibility I could screw anything up however minute it may be.
You actually still hide a lot because you never actually opened the case to see if it was fluid failure. It could have been slug of clutch material dislodged by the new fluid that clogged an orifice or accumulator. Frankly you have no idea why it failed but you assume the new fluid was the cause.
You are treating this as if someone who just changed from conventional oil to synthetic but then lost compression on a cylinder(s). They proceed to blame the oil as if it had anything to do with it. It is pure and simply a mechanical failure as there is no way the right fluid could do that.
You used the right fluid and it still broke, mechanical failure pure & simple. You may not want to hear it but I can't stand it when someone says something so false about a product with really nothing to substantiate it.
Thanks for the tip
It works like a charm too.
Very strange. I asked because I was beginning to wonder if there was some bottling error and this was not MaxLife ATF at all. If viscosity and everything else were out of whack, that might have been an explanation.
You're just a pot calling the kettle black. Do you really care that much what I think? I say the fluid caused the failure. I spent almost $3k to call the failure whatever I want and couldn't care less what you think.
Funny how easy it is for people like you to spend my money. How was this supposed to happen? I have someone tear the trans down and be without a vehicle even longer to find the cause and be no farther ahead so I can vindicate the MaxJunk fan boys on BITOG? I think not.
If you like that junk, use it, I'm not. If you don't like what I have to say no one is forcing you to read my posts. Just press that button that reads, "MaxJunk fan boys ignore button" and your life will return to normal.
Nice isn't it? Even on ignore, all one has to do is quote and you see everything. Kinda defeats the purpose, ha?
Even with ignore i can still see others quotes from the ignored person.
Only God knows. All I know is I won't buy anything from that company ever again.
Why me? I'm happy. On the other hand YOU are the one that blew a gasket earlier with the anger and name calling. I slam Valvoline because I can. You don't like it for whatever reason and act like a lunatic. Is this really that important to you?
You need a time out.
