I recently put a high vol oil pump in, and I was just wondering about the max flow rate of the filter which is 7-9 GPM. With the high vol oil pump @ redline the flow should reach ~17 GPM, will the filter limit the oil flow?
also I was looking to use a bigger filter, I found a larger one but the nominal micron rating is 30, whereas the stock is 20, is that a problem?
