- Joined
- Jun 8, 2022
- Messages
- 5,676
I have two Nissan transfer cases - both call for Matic D - they also have a foot note that in Canada they can use Dex3/merc. The transfer case is the same - all these vehicles assembled in TN - so I assume Dex3 is fine anywhere. Read here there pretty much the same also.
I switched to Max Life due to cost. In the year or so since, they started to struggle to go in and out of 4wd. It takes a while - sometimes you need to stop, or even back up. Also, when I changed one had like 300K miles on it, the other about 100K, and neither did it before, so it could be because there getting older, but it seems odd they both start now.
So was thinking of going back to Matic D - its much thicker by spec. But its about $14 a quart. I only need 2.1 quarts per case, so its not earth ending. But wondering if there is a better Dex3 option. I at least want the proper dex3 viscosity, and I think its mineral oil. I see Valvoline has one in a blue bottle, but between this and the recent posted 75w90 test results, I think I am staying away from Valvoline.
Thoughts?
Thoughts?
