Master Power ac any good?
NJ
On Craigs List MPAC521 Master Power air compressor by Cooper Tools $75 150psi 5.6cfm@90
Any good? Price? Better value and compressor at HF?
Fixable? Parts available? If diaphragm goes in pump?
Originally Posted by Chris142
Oil less junk?
I've had my Craftsman 2 stage 60 gallon oilless compressor for over 10 years and run it most every day. Never failed and I have it set at 160 psi.
Originally Posted by Donald
Not sure if I would believe the 150 PSI. Typically only an expensive 2 stage compressor can get to 150 PSI.
Just about any 1 stage can eventually pump up to 150psi, Judging by the CFM, This is a small portable compressor & 150 is Max
Oil less junk?
I don't doubt that, But how many hours are on it? Even then hours don't give the full story without duty cycle.
