- Joined
- Oct 16, 2023
- Messages
- 271
I noticed I had some clutch pedal play on my 96 f150 with rhe M5OD so I stuck my head down there to inspect. I found the rod had a bad bushing which is what I expected it was almost off its attaching point. I unhooked it from the pedal completely and noticed the rod come out pretty easily. Is that normal? I assumed the rod shouldn’t come out of the master cylinder that easily? I stuck it back in and popped the linkage all the way on and zip tied it until I can get to fixing it. Originally I was planning on just a bushing since the rod end looked ok minus the bushing, but with how easy it came out of the master cylinder Portion I’m not sure if I should just replace the entire master cylinder. Your thoughts? I haven’t really tested how firmly attached the rod should be so I don’t have a great comparison point.
