Good Afternoon - I have a 2004 Dodge Caravan 3.3 liter v6 automatic. I run Mobil 1 Extended Performance and a Mopar filter. I had 3000 miles and 5 months on the oil change when I towed a 1300 pound trailer into the North Carolina mountains. The roads were so steep my tach was at 5000 RPM to maintain any speed at all. On the way back, I checked the oil and found it one quart low. I added a quart of oil ( Thanks Walmart ! )
Does it sound like the oil is sheared down and needs changing? The car has never used oil before.
I do a pan drop and change the ATF in the pan and filter once a year when I tow. I also vac another 4 quarts of ATF out and replace it once a year.
THANKS IN ADVANCE FOR ANY ADVICE
