Mercruiser recommends 3 different types of grease for gimbal, splines, and fittings. I have found Pennzoil Premium Plus Multo-purpose marine grease that can be used for wheel bearings, and also mentions other bearings such as splines, bushings, pin and bearings. Would this 1 grease be sufficient to replace all 3 of the ones that Mercruiser recommends? I just find it hard to believe that these are that different, and keep in mind that I live in Indiana, store the boat in-side when not in use, and put about 20 hours a year on the boat.
Thanks for the advice.
