I've read for hours. I know there is much antidotal comments on here (and everywhere) but I also know many of you are engineers, oil nerds and just **** smart with good seat of the pants data.
As I determine my oil needs for my marine gas engine with a an approx. 330hp 7.4L (fuel injected) but not sure on cam but the original engine was a 1997. This is a newer long block...I get really confused, quickly.
1. Some of you say HD diesel oils of the right viscosity are great. High and zinc and built for HD rpm over long haul then...
2. The next guy says no diesel oils (even if spec'd for gas) in boats as the detergents will foam under the higher (3000?) rpms
3. then there is much discussion of one guy running 30, then 40 then 50 all in various configurations from 30 weight (what my original Volvo Penta spec'd in 1997) to my recent mechanic buddy saying to run 20W50 (VR1) or 25W40 full synth.
4. Next guy says marine engines are all marketing and over priced and no different then HD oils
Holy cow guys...what's a girl todo? So much info and so much discussion. What's the science tell us? When we don't know the rings, pistons, cams on a newer long block? The manufacture didn't give much specs other then what todo (and not) in the first 10 and 20 hours.
