I'm having a hard time figuring out what's wrong with my transmission.
I just got the clutch replaced, since the pilot bearing went out, and was squealing like crazy when the clutch was in and I was putting it into gear.
Clutch aside, I've been having trouble getting it to go into gear for a while. I thought it might have been the clutch, but since it's just replaced, I guess not. Here are the symptoms:
Stopped at a red light, with the transmission in neutral, it doesn't go straight into first- it hangs up about 60% of the time. If I shift it into some other gear and then back into first, it goes fine. It doesn't always want to go into the other gears either.
Sometimes, if I just pause a second, it'll go into gear without any force. Sometimes not.
No problems downshifting- no grinding, nothing.
I'm kind of bamboozled- it shouldn't be a clutch issue at this point, but what part of the transmission is it, and are there any work-arounds or techniques to minimize it?
