michaelc80, which Red Line gear oil did you use? 'Regular'? NS? Shockproof? Have you tried to use MT-90 in the same application? It sounds like you used 'regular' Red Line gear oil which isn't friction modified for synchronized transmissions ... and you're saying it's the best you've tried to date?
Transmissions are picky things. I'm convinced there is no perfect choice for all transmissions. You can ask around and see what others are using in the same or similar applications but when it really comes down to it, there's a lot of "poke and hope" involved.
I had heard years ago some people saying that (in general) Red Line gear oils seem to do better in many applications than comparable oils from Amsoil (some Amsoil fans belatedly admitted this). I thought this was seriously dated ... but maybe not.
scoobdude "Although I don't like to mix oils, in this case it's the only solution as the Pennzoil is GL-4 and the Amsoil is GL-5."
It might be a solution to make the best of the oil you already had in your transmission ... but these days there is a plethora of synchromesh fluids available in everything from ATF weights all the way up to XW-90 weight gear oils.
If you do a search on "MTL-R" or "WRX," you'll see a few Soobie drivers here that have had great luck with Specialty Formulations MTL-R ... my first pick in applications calling for a 75W-90 ... even over anything available from Red Line.
--- Bror Jace
--- Bror Jace
