Hi guys,
This is my first post, the guys on the Porsche board couldn't really give me a straight answer so I thought I turn here for help.
I have a 1999 Porsche 911 Carrera 4 (4 wheel drive model) so far knock on wood everything seems to be in working order except some minor crappy loose interior trim noise, minor exhaust rattling sound and the way the transmission shifts, especially when it is cold. It is almost impossible to shift to first gear unless the car is stopped completely for few seconds when cold, and very notchy going to 2nd. Once the car is fully warmed up it is buttery smooth. So I want to change the transmission gear oil to see if it would make any difference.
After checking with Porsche related web site I have gathered some information but still couldn't answer all my questions.
This is what I know so far:
(1). I need to use oil that will protect both the differential and provide enough friction for the synchros to work since the transmission/differential unit in the 911 is a combined unit in design (Thus share the same fluid)
(2). Mobilube PTX (synthetic) 75W-90 GL-4, GL-5 is what the factory recommends. The GL-4 rating supposely provides enough friction needed for the synchros to work properly, and the GL-5 provides protection for the differential under high pressure environment. So the gear oil needs both the GL-4 and GL5 rating and mix.
(3). Can't get Mobil PTX here unless you want to pay outrageous price from the dealer.
(4). I was told that the Front tranaxle uses the same oil as the transmission GL4/5. (On a C4) Just curious of the construction component of the front transaxle if using GL4/5 would be suited. As the factory shop manual states using ATF fluid, which was later found to be a typo.
(5). Someone recommended using Silkolene Silktran SYN 5 API GL4/5 75W/90 as a substitute, which is available in the US for $15 / liter. Have anyone tried this?
(6). What oil recommendations do you guys have?
Just curious if I am on the right track?
The shop manual is also not too clear on this subject, so I want to ask the board to see if anyone can shine a light on this subject.
TIA
Robin
TIA
Robin
